MX75 - how to identify which mac addresses is attached to which interface
JDes
Reviving an old topic (last posted in 2017). I know I'm not the only one looking for a 'show mac address-table' equivalent so I can see who is connected to a given port on my MX devices.
2 Replies 2
You can see this from the new topology view (at least if you have a switch in the network).  Below you can see that port 3 on the MX is connected to port 8 on the switch.  Note that this is LAN port 3 on this MX75 which is actually labelled 7 on the unit as they start from 0 and the first three ports are WAN ports.
RaphaelL
Hi ,
At the moment you can only use https://developer.cisco.com/meraki/api-v1/get-device-live-tools-mac-table/ on switches. So I don't think there is any way to get the equivalent data on a MX.
Edit: My reply is only for the API. As noted by cmr , you can view some of the info via the dashboard ( Topology ) or liveTools (ARP table)
