MX Security Inquiry
Enrico_Romero
MX Security Inquiry
Hi Guys,
Good Day!
I got an opportunity to present Cisco Meraki Security on one of our Partner's End User.
There are some inquiries about Meraki's Security Solution:
  • Is it possible to place a Bandwidth Limitation for Groups/VLAN's?
  • In youtube, can Meraki Block the Category? (e.g. Allow Manufacturing Videos but block other kinds of Category)
  • When viewing Sites that has Advertisements, can Meraki Block those Ad's? (It will just show a White Picture and its not click-able)
  • Since Meraki has 10yrs License option, if in case the unit still has 10yrs and its about to approach End of Life. Is there a REFRESH program? (e.g. A Buy-Back program that will have less cost when getting the replacement)
They are also familiar with Meraki's AP.
But they have 1 question in mind and it has to do with MAC ADDRESS Binding per SSID.
Is it possible to have a MAC ADDRESS bonded to an SSID that has Traffic shaping? (e.g. MAC addresses of a certain group can only connect to a specific SSID, if they connect to a different SSID they won't have internet access).
I know this is a long post but I really appreciate any feedback from you guys.
Thanks in advance!
Yes.
https://documentation.meraki.com/MR/Group_Policies_and_Blacklisting/Creating_and_Applying_Group_Poli...
No.
There is a content category called "Web Advertisements",  I've never used it, but I expect it would block what it says.
Discount programs come and go.  You should not enter into a 10 year transaction with any expectations.  Seriously though - would you really want a security appliance using 10 year old technology.  I would suggest shorter licences, like 5 years, and replace the device more regularly.
1 Reply 1
Yes.
No.
