Field "notes" is not showing in Dashboard (MX Appliance status)
VictorMatheus1
Hello everybody,
I'm facing a possible failure in the MX dashboard (Security & SD-WAN > Appliance Status).
The "notes" field is not loading previously saved information.
Anyone else with the same problem?
Best Regards,
(edit: I'm in the South America (Brazil) region)
Ryan_Miles
Looks like it's resolved now
Ryan / Meraki SE
If you found this post helpful, please give it Kudos. If my answer solved your problem click Accept as Solution so others can benefit from it.
5 Replies 5
rhbirkelund
Could seem to be a known error on the backend. Others have reported the same.
https://community.meraki.com/t5/Dashboard-Administration/TAGS-NOTES/m-p/191444
@rhbirkelund  Thanks for informing!
CoreyDavoll1
Just as I had something important to put in there lol
Hoping it will be recovered soon.. 😕
Ryan_Miles
Ryan / Meraki SE
