Duo MFA for Meraki Cloud Authenticated users?
WarrenG
Is it possible to use Duo to require MFA for Meraki Cloud Authenticated users while using Meraki Client VPN? Specifically we need to use the AnyConnect option with Meraki Cloud Authenticated users, but need to be able to protect that connection further with MFA. Is this scenario possible?
No.
You could use AnyConnect and Duo, and authenticate against Office 365.  I would use this option.
You could use a machine running inside of the network running the Duo Auth proxy and configure the MX to do RADIUS against it, and have the auth proxy configured to do MFA only.
This would result in the username+MFA being used, but the password being ignored.
Inderdeep
@WarrenG Check this one out may help
https://documentation.meraki.com/General_Administration/Other_Topics/Two-Factor_Authentication
Regards/Inder
www.thenetworkdna.com
So the answer is no then?
No.
Thanks PhilipDAth. If the answer to my question is no, then that's what I was looking for. I know about the other options, but they are not viable for what I'm needing in this specific case.
