Disable Cellular on MX units on Dashboard
nline
the company I work for has several MX series units at our various locations.  Many have a Cellular ability but no SIM card has been installed.  We are not using the cellular function only ethernet cables plugged into WAN1 or sometimes WAN1 and WAN2.  We don't need cellular connections at these sites. (Too expensive and too unreliable for sites that are not mission critical.)
So our dashboard shows us under the uplinks box  N sites offline.  These are the sites that don't have SIM cards and we don't intend to install any.
How do I turn this off per unit so that we aren't getting false reports of an uplink being down?  I can't find anywhere in the dashboard to turn this off.
Nline
1 Reply 1
