This is going to depend on your ISP.
If they use PPPoE, then yes you can bridge it through.
If they use PPPoA, then no you wont be able to bridge it through.
If they use a layer 2 service delivered over Ethernet and DHCP, then yes you can bridge it through (actually you would just plug this circuit directly into the MX).
