Circumvention Technology/Internet Censorship Circumvention
Yifeng
Hello there,
Greetings, does any one know if that can be done by setting up Meraki site-to-site VPN to achieve that. It's kind a little like circumvention technology (or Internet Censorship Circumvention).
We have branches both in Taiwan and China. We would like to connect to some specific website via Taiwan or China external IP. The network path should be like this, Users (Internal IP) --> US Meraki MX (Internal IP) --> MPLS site-to-site VPN (Internal IP) --> China or Taiwna Meraki MX (External IP) --> Specific Website.
Or, because we have a class C network can use, is there a way that I can setup a static route in Meraki MX so that we can use a different external IP to reach that website?
Please help, thank you.
Sincerely,
Yifeng
Adam
Inside of the Meraki platform, I don't believe there is a way to do this yet.  I use Layer 7 to block certain countries and there isn't even a way for me to make an exception to that if I want to whitelist a few URLs.  So as @PhilipDAth pointed out, your solution will likely be outside of the Meraki platform.
It is probably easiest to deploy a proxy server in each location (like squid).  Then create a WPAD auto-proxy configuration script (which web browsers use) and tell it which sites are to go via which proxy.
You'll want a VPN linking the two sites so users at either site can use either proxy server.
Thanks, I will consider this option.
Adam
