Meraki Go Outdoor WiFi 6 Access Point
Gislavedshus
Hello!
I would like to buy a Cisco Go AP for a Ladd box. According to the picture I will put an AP in the house (on the right side with red signal) and on the other side in the parking lot I will add a Ladd box (with red signal).
The distance between them almost 60-70 meters.
Can you recommend us a good coverage AP with the price in mind as well?
Bassam Addas
1 Reply 1
Gislavedshus
Can we used Meraki Go Outdoor WiFi 6 Access, it will be a good coverage?? ( 60-70 m)
Bassam Addas
