Home network advice - Meraki Go
Navneet
Hi folks, non-technical person here, so please bear with my silly questions.
Background - I am looking at the Meraki-Go Security Gateway, for 2 reasons:
- to strengthen security/ protection on my home network; &
- 'observe' what my two teens are upto.
I already have a Wi-Fi network set up (3000+sq ft house) using a Deco Mesh system - wireless APs.
My questions are:
1. Will Meraki-Go Security Gateway work with my third party APs and router?
2. Is the Gateway enough or would you also suggest the switch or other gear?
Any guidance to a networking newbee will be much appreciated. Thank you, Navneet
Fibo
Yes the Gateway works with 3rd party devices. Alltough the feature are a bit limited at the moment since you can't block a client for exemple if it's on a 3rd party AP.
For your use case however this shouldn't be a problem.
DarrenOC
@MeredithW  - Believe this should be relocated to the Meraki Go forum.
Fibo
Navneet
Thank you so much. Much appreciated! I have ordered it.
