HOWTO: Silent Install of SM agent 3.1.0 and above
PaulF
I know that there's many of you that have workflows that involve the manual install of the SM agents on macOS, such as Silent installer for MacOS
However, with the changes in the SM agent 3.1.0 and above, instead of being able to do silent installs, you know have to specify your enrollment code manually, as per Mac Enrollment - Command Line Options
You can optionally specify the network enrollment code / string with the following command:
sudo launchctl unsetenv enrollment_code && sudo launchctl unsetenv organization_id && sudo launchctl setenv enrollment_code <network enrollment code or enrollment string> && sudo installer -pkg <path/to/package.pkg> -target / && sudo launchctl unsetenv enrollment_code && sudo launchctl unsetenv organization_id
 There's two optional parameters here:
<network enrollment code or enrollment string> : This is the enrollment code that's quoted in Systems Manager > Add Devices, or Network Wide > General
<path/to/package.pkg> : This is the path to the SM agent installer
This is, understandably, unwieldy, primarily due to not being able to pass parameters to installers in macOS.
However, there is an alternative: You can actually build an installer that allows you for silent enrollments, and this is how
1. Download the Current SM Agent Installer
From Systems Manager  > Add devices > macOS, download the SM agent
2. Create a new folder on your Desktop: SMAgent3.1.1 (for example)
3. Open Terminal and type the following
cd ~/Desktop/SMAgent3.1.1
mkdir Scripts
cd Scripts
touch postinstall
chmod a+x postinstall
cd ..
mkdir Content
cd Content
open .
This last command will open the Content directory
Move the previously download SM agent into here and rename it SMAgent.3.1.1.pkg
Go back to terminal and type
cd ..
cd Scripts
open .
This will open the Scripts directory in Finder.
4. Edit postinstall
With a suitable text editor, open the postinstall file and type:
#!/bin/bash
sudo launchctl unsetenv enrollment_code && sudo launchctl unsetenv organization_id && sudo launchctl setenv enrollment_code XXXX-XXXX-XXXX && sudo installer -pkg /tmp/SMAgent-3.1.1.pkg -target / && sudo launchctl unsetenv enrollment_code && sudo launchctl unsetenv organization_id
NOTE: Replace XXXX-XXXX-XXXX with the network enrollment code or string
Save this file
5. Create installer
Go back to Terminal and type:
cd ..
sudo pkgbuild --identifier com.meraki.smautoenroll --root Content --script Scripts --install-location /tmp com.meraki.SMAgent3.1.1-autoenroll.pkg
This should result in:
paulf@Paul-F-MBP-680 SM3.1.1pkg % sudo pkgbuild --identifier com.meraki.smautoenroll --root Content --script Scripts --install-location /tmp com.meraki.SMAgent3.1.1-autoenroll.pkg
Password:
pkgbuild: Inferring bundle components from contents of Content
pkgbuild: Adding top-level postinstall script
pkgbuild: Wrote package to com.meraki.SMAgent3.1.1-autoenroll.pkg
You should now have an installer that will silently install the SM agent without prompts!
1 REPLY 1
ConnorL
This is brilliant, thank you @PaulF for sharing!
