Dashboard connectivity in Europe region
pratikvyas
Hello Everyone,
We are aware of Meraki nodes reporting issues with dashboard connectivity within the EU region. If you have nodes losing connectivity to Dashboard and if your dashboard organization is hosted in Europe then it's most likely related to this. You can verify by scrolling to the bottom of the page and it would say which region your organization is hosted in.
End-user traffic should not be impacted by this. It has been marked as Sev 1 internally and we are working on addressing it with the highest priority. Please follow this thread for updates.
Updates will be provided below as a new comment to keep you updated.
Thank you for your patience.
7 Comments
JoshNansoz
Update 8:25 GMT Wed 23rd March:
Our engineering team continues to work on this issue as a top priority.
Scope of issue:
  • Dashboard connectivity to some nodes in the Europe region is affected.
  • End-User traffic is not directly affected
    • i.e. if your device is "offline" from Dashboard, it will still pass all the traffic as it was configured to do so before this issue
  • Some Meraki services may not be fully operational
    • e.g. if you have 802.1x using Meraki Auth, this may not be fully functioning.
JoshNansoz
Update 9:05 GMT Wed 23rd March:
  • Our engineering team is fully engaged on this issue
  • Configuration changes to devices may take a significant time to reflect on the device or fail completely until this is fixed.
JoshNansoz
Update 9:45 GMT Wed 23rd March:
  • Our engineering team is reporting that services are starting to stabilise.
  • Engineering found the cause of the issues and deployed changes to remediate them.
  • If you continue to see issues today, please do contact our Support Team.
Cisco Meraki will be providing our customers with a more in-depth explanation of what happened at a later date.
PhilE
Update 10:35 GMT Wed 23rd March:
  • The issue is still ongoing
  • Engineering is continuing to work on a resolution to the issue
PhilE
Update 11:55 GMT Wed 23rd March:
  • Engineering is continuing to work on a resolution to the issue with the highest priority.
PhilE
Update 13:30 GMT Wed 23rd March:
MelB
The issue is now RESOLVED
We have taken action to help prevent this from reoccurring
Dashboard connectivity affecting MX 16, MR 28 nodes in EMEA was observed
Further updates to follow.  Please reach out to Meraki Support for further assistance.
