Test connection website fails, to Meraki Go success - from Go access point
IanTerry
Hi all,
I have an odd problem, configured Go access points in the usual way, as I have done for customers previously, except this time the wireless repeatedly starts/drops. investigating the access point, it is available. Running test connections, to MerakiGo is fine to a test website (www.cisco.com) fails, same for any website.
Anyone know how the Test Connection works - is it a simple PING or does Test Connection use specific application ports numbers with UDP or TCP ?
Anyone else had a similar experience access point flapping on firmware 28.x ??
Many thanks
regards, Ian
0 Replies 0
