Advanced Security License
DC3
Is it no longer possible to purchase the advanced security license for Meraki Go? Even on the Go website, all of the preferred vendors are out of stock and don't have any way to purchase a license.
Between the licensing and much of the switch hardware no longer available for purchase, I'm a bit concerned about Meraki's commitment to the Go line of their products.
ArtMarshall
Meraki Alumni (Retired)
Hi there,
What country are you purchasing in? I see that CDW has it as does SHI.
It does look like Rhino's page may have a problem so we're reporting it to them.
Hope this helps,
Art
ArtMarshall
Hi there,
Hope this helps,
Art
DC3
Thank you, I do see those two options available now.
I’m in the US, I’ve checked a several of the preferred partners but hadn’t seen any available options to actually purchase. Amazon, Rhino, and even the two you posted either don’t have any availability or didn’t when I checked previously. Hopefully some of the other partners will begin stocking these things. It doesn’t instill a lot of confidence in the customer base when none of the products are available.
Thanks again.
speakerfritz
I bought mine a few weeks ago from B&H photo.  They are a large electronics reseller.
