As a production company we have may external suppliers who deliver machines or software to support our product processes.
Many of these suppliers will always try to bring their own router to be able to support the machine or software.
Often these machines or software also need to exchange data with internal machines or software.
I need your opnion here. How do you handle situations like this? What kind of policy you have here. And what is the best solution in these situations? Place them behind a separate mx for each supplier?
Solved! Go to Solution.
Place them behind a single MX with each on their own VLAN would be my suggestion although how many suppliers at any one time would you have onsite?
I wouldn't allow third-party network equipment to be connected to your internal network.
I often put them on their own VLAN, for a VLAN separate from the internal network, and provide them with VPN access to their devices.
It can vary, from one to ten or fifteen per location.
Depends on the level of automation within a location.
Then you have the same thought as me. But it is something that has been accepted for years, but in my opnion cant be any more.
I agree. The threat landscape has evolved, and security systems and practices must evolve as a result.
agree with everyone, set up a separate VLAN just for them and if not required, just hand out a static IP.
Thank you all for your answers. This helps me.
