Cases of other Organization also showing up
DarwinV
We are currently managing 2 clients of which they have their own separate organization. When I login to my account, I can basically switch from one Organization to the other which is cool.
But its kinda confusing that filed cases for both Org-1 and Org-2 are showing up in the Cases page. Sometimes you may mistakenly filed a case or follow up a case of Org-1 but you are currently working on Org-2 and vice versa.
I was hoping that if I select Org-1, cases that would show up should only by those filed for Org-1 to avoid confusion and possible mixing them up.
Thanks.
3 REPLIES 3
DarrenOC
Hi @DarwinV - that is as expected. As an Admin of multiple Orgs you will see cases for all Orgs that you are admins of.
DarrenOC
I can’t see a way of filtering by Org or site within the Cases/Help section.
Maybe when submitting your cases include the Org and Site in the Subject header.  That way you’ll be able to save yourself any confusion
DarwinV
If other admins doesn't see this as a problem, then I guess I'll have to follow your suggestion to put a prefix on the subject line.
Thanks.
