A new stable wireless firmware version is available. Firmware MR 30.6 was just released on 2024-01-17 and has been in this firmware category since 2024-03-25.
AP not returning to original channel after a DFS channel change event occurred (MR45/55)
Large mDNS packets can cause loss of wired connectivity (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
User-Name and Calling-Station-Id in different format consuming additional license on ISE (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
UDN ID not properly assigned to clients for "iPSK w/ RADIUS" configuration (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
Incorrect IPSK-EAPOL VSA data for Easy PSK (Wi-Fi 5 Wave 2 APs)
Exclude Beidu/GLONASS constellations from GNSS receiver when used for AFC location (Wi-Fi 6E APs)
6 GHz radio not turned off when AFC expires (CW9163E-MR)
APs utilizing WPA3 are shown as "Open" in RF Spectrum > Interfering APs UI (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
Clients getting dropped before DHCP lease time expiry during L3 roam and disconnected for more than 30 sec (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
AP failed to change channel (Wi-Fi 6 and Wi-Fi 6E APs)
Enhancement
Add 6 GHz support for regulatory domains with new 6 GHz approvals (Wi-Fi 6E APs)
Keep 6 GHz radio off for outdoor APs when no configuration provided (CW9163E-MR)
Upgrade CiscoSSL from 7.3 to 7.3a
Known issues
Sporadic packet loss & instability on Layer 3 roaming & Teleworker VPN SSID's (Wi-Fi 5 Wave 2 and Wi-Fi 6 APs)
In high capacity wireless networks, APs may experience instability when the “Client Balancing” feature is enabled (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
DNS test failure results in no connectivity (Wi-Fi 5 Wave 2, Wi-Fi 6 and Wi-Fi 6E APs)
To start contributing, simply sign in with your Cisco account. If you don't yet have a Cisco account, you can sign up.
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6ec4daa079ea37","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6ec4daa079ea37_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6ec4daa079ea37_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_6ec4daa079ea37_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_6ec4da985c65b5","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
