A new candidate switchCatalyst firmware version is available. Firmware CS 17.1.3.1 was just released on 2024-10-08 and has been in this firmware category since 2024-10-08.
This version's IOS image is based on 17.12.3 CCO. Upgrades to this version will result in a full system reload.
New feature highlights
Client Analytics
Device Uptime for MS390s
EEE (Energy Efficient Ethernet) Support
Multi-auth with support for guest/failed/critical
RADIUS Caching
VLAN to SGT mapping
General fixed issues
Fixed an issue causing switches to restart after stack failovers
Fixed an issue that caused incorrect PoE usage data to be shown in dashboard
Ms390 fixed issues
Fixed a problem that allowed MS425 devices to perform client sampling on ports directly connected to downstream MS390 switches
Resolved an issue that prevented the application of fixed IP assignments if the IP being assigned had an active DHCP lease
C9300 known issues
Downstream clients may experience packet loss for 60-200 seconds stack while the standby switch takes over the active stack member role when the active stack member is powered off
General known issues
Management plane connectivity may be interrupted when there are a large number of LLDP announcements
Meraki native switches move LACP ports to an active forwarding state if configured. This can cause loops when connecting to an MS390 or other Catalyst switch unless the bundles are configured on the Catalyst side first. All Meraki native ports are configured in passive LACP mode so that loops do not occur between Meraki native switches (always present)
Stacks of 5 or more switches may experience a configuration mismatch when making multiple consecutive port configuration changes to several interfaces in a row
To start contributing, simply sign in with your Cisco ID. If you don't yet have a Cisco ID, you can sign up.
