Smart Thresholds for web applications
Monitoring business-critical web applications just became even easier with Meraki. Simply select the application(s) you want to track and toggle on Smart Thresholds. No thresholds need to be set at all – Smart Thresholds will use machine learning to automatically adjust thresholds for web applications based on the past behavioral patterns and performance for that application and the network it’s been running on.
