ModuleNotFoundError with PyInstaller
Diniguez
Hello everyone!
I am trying to create a console based app with PyInstaller.
In my project, I am using the Meraki library just with:
import meraki
I can run my project from the py file, but when I create an exe file with PyInstaller, I get this error:
ModuleNotFoundError: No module named 'meraki.__init__.rest_session'
I have tried creating a different venv and installing the necessary packages, but the error persists.
I have tried the following commands to create the exe with no luck:
pyinstaller Menu.py
pyinstaller Menu.py --hidden-import meraki.__init__.rest_session
Could you please advise what should I try next?
1 Reply 1
Vitorio
I had this same problem and fixed the issue by updating the meraki library:
pip install meraki --upgrade
After the update the error did not appear anymore.
