Managing network with MX64W
TimKud
I'm curious if it is possible to manage the wireless settings of an MX64W with v1 of the API. Trying to use /wireless/ssids doesn't seem to modify the settings but does return successful and does show when I get the list of SSIDs.
Jon_Hartman
While v0 was flexible in this regard, this is a known coverage gap in the v1 API. The current endpoints are MR-specific.
Given it will be sunset eventually, I can't recommend building integrations off of v0, but you may find success there, until v1 supports MX wireless configuration.
2 Replies 2
Jon_Hartman
TimKud
Thanks, Jon. I figured that was it because I could swear I was able to mess with them in v0. We'll probably implement v0 temporarily if we end up needing it for our automation, until v1 provides support for it.
