Endpoint for Umbrella status on MX
KarstenI
I don't find the endpoint to query if Umbrella is enabled on the MX and if yes with which settings. Any hints for me?
Have a great weekend, Karsten
It really doesn't, unless the information is hidden under lock and key. 😅
Are you trying to find it on the Umbrella page or on the Meraki Dashboard Page? On Umbrella you can check here:
 On Meraki you can check under Network-wide > Configure > General
By the way, there is no API to check if Umbrella is enabled.
This is what I want to do. Really no API for this? That would be quite disappointing.
