@PhilipDAth wrote:
Meraki should trust LetsEncrypt.  Their CA is dual signed by someone else who I can't remember as well, so it really should be trusted.
Maybe try using SSL tester to make sure it isn't something dumb like a weak hash for weak cipher is being used.
https://www.ssllabs.com/ssltest/
From what I know of, Letsencrypt is trusted by all major Root CAs. So in principle it should be secure enough.
On the other hand, I remember to have read somewhere that many don't see Letsencrypt as a safe free encryption body any more, due to its ease in creating SSL certificates.
Before, you could trust that if someone uses HTTPS the website was regarded as safe/free of malicious software, because certificates weren't easy to get, and people trusted it. With Letsencrypt, it has become too easy for malicious entities to create websites, even using Letsencrypt.
	LinkedIn :::
https://blog.rhbirkelund.dk/Like what you see? - Give a Kudo ## Did it answer your question? - Mark it as a Solution
🙂All code examples are provided as is. Responsibility for Code execution lies solely your own.
