Alerts endpoint returning 404
bryand23
Edit: Nevermind, I'm using an Org ID instead of a network ID. I should know better, I've made this mistake before 🙂
I'm trying to access the API endpoint for Network Alert settings, and I'm getting a 404 for that URL.
I'm able to access other endpoints just fine, sample code below.
from meraki_sdk.meraki_sdk_client import MerakiSdkClient
from meraki_sdk.exceptions.api_exception import APIException
x_cisco_meraki_api_key = my_api_key
client = MerakiSdkClient(x_cisco_meraki_api_key)
alert_settings_controller = client.alert_settings
network_id = 'NETWORK_ID' # I've tried with multiple networks
try:
    result = alert_settings_controller.get_network_alert_settings(network_id)
except APIException as e:
    print(e)
HTTP response not OK.
I tried accessing the same endpoint with the requests module to rule out an issue with the Python SDK:
import requests
headers = {'X-Cisco-Meraki-API-Key': 'my_api_key', 'Accept': 'application/json'}
url = '<a href="https://api.meraki.com/api/v0/networks/NETWORK_ID/alertSettings" target="_blank">https://api.meraki.com/api/v0/networks/NETWORK_ID/alertSettings</a>'
response = requests.get(url, headers=headers)
print(response.status_code)
404
Other URL's such as list organizations, list admins, etc. all seem to work fine with the same code.
2 Replies 2
BrechtSchamp
Good to see it's solved. And great to see the syntax highlighting feature put to use.
Yea, it's nice! Though it appears to be autoformatting my URL and adding a bunch of extra HTML.
