API v0 EOL verification question
PatWruk
I just received an email saying the extended grace period is expiring January 31st, and I'm getting the email because I haven't moved to v1 yet. I just checked all of my scripts that use the Meraki API and checked the API call "organizations/{orgid}/apiRequests?version=0" and nothing is using v0 anymore. Am I missing something?
It should probably just be an informational message.
8 Replies 8
That's what I was hoping, just wanted to make sure I wasn't missing something that I should check.
rhbirkelund
I’m getting the same message, and afaik I’m also not using the v0 API, eventhough the email directly says I am.
A call to the v0 API looks like:
https://api.meraki.com/api/v0/organizations/...
 A call to the V1 API looks like:
https://api.meraki.com/api/v1/organizations/...
There is nothing that uses "?version=0".  Instead search for "/v0/" in your code.
I think you misunderstood what I was saying. If you run the api call https://api.meraki.com/api/v1/organizations/{orgid}/apiRequests?version=0, you get a recent list of v0 api calls, if you change it to version=1, you get a recent list of v1 api calls. As explained here: https://community.meraki.com/t5/Developers-APIs/Identify-API-v0-usage-the-easy-way-0%EF%B8%8F%E2%83%...
Oh, you are correct.  My mistake.
Ryan_Miles
You can also run the API requests call with parameter version to verify no version 0 calls have been made in the last 31 days
Ryan / Meraki SE
If you found this post helpful, please give it kudos. If my answer solved your problem, click "Accept as Solution" so that others can benefit from it.
Guillaume6hat
Hello.
I received the same email.
I tried to look for any v0 call in my code, but nothing.
Then I used the API call "getOrganizationApiRequests" , with option version = 0, to check any usage with this version.
Surprisingly, I have a lot ! But it seems it's a mistake :
        "adminId": "xxxxxxxxxxxx",
        "method": "GET",
        "host": "nxxx.meraki.com",
        "path": "/api/v1/organizations/xxxxxx/appliance/trafficShaping/vpnExclusions/byNetwork",
        "queryString": "perPage=1000&startingAfter=xxxxxxxxx",
        "userAgent": "python-requests/2.31.0",
        "ts": "2024-01-22T01:44:45.110913Z",
        "responseCode": 200,
        "sourceIp": "xx.xx.xx.xx",
        "version": 0,
        "operationId": "getOrganizationApplianceTrafficShapingVpnExclusionsByNetwork"
Apparently, every "getOrganizationApplianceTrafficShapingVpnExclusionsByNetwork" call is categorized as version 0, even if in the path we clearly see it's v1.
I'm wondering if there are other calls impacted, and maybe Meraki checks for each Org if there is any v0 call the same way, and as there are some wrong categorization, that's why we receive these emails ?
