Dashboard Info MX Security
GaryShainberg
Does anyone know how to stop the MX data appearing on the Meraki dashboard app on the iPhone when you show “local connection”
-G
CTO & Solutioneer
CMNA, CMNO, ECMS2
SNSA, SNSP
DCooper
Meraki Alumni (Retired)
Disconnect from the WiFi.
DCooper
Adam
-G
I believe this is the same information you can get by going to my.meraki.com when connected to any Meraki network.  You can turn that stuff off by going to Network Wide>General and changing 'Local device status pages' to disabled.  It's an all or nothing setting I believe.
