Change log monitoring
ZedKay
Does any know if the Organisation Change log is able to monitored or sent to an 3rd party via the API?
I cant seem to find any information on it.
Essentially we want to be able monitor for changes & create tickets in our service desk platform.
Z
Ryan_Miles
https://developer.cisco.com/meraki/api-v1/#!get-organization-configuration-changes
Ryan / Meraki SE
If you found this post helpful, please give it Kudos. If my answer solved your problem click Accept as Solution so others can benefit from it.
Ryan_Miles
Ryan / Meraki SE
ZedKay
guess i didnt look hard enough.
Ha, no worries. The call doesn't say changelog in it so the search function isn't catching it on that keyword.
Ryan / Meraki SE
I also now stumbled across the webhook alert settings_changed
https://documenter.getpostman.com/view/897512/SVfRtnU7?version=latest#ed28e32f-80a7-4a5e-8a04-35addf...
will give that a go as well.
