Cloud Monitoring Prerequisites
Before you begin, here's a handy checklist that will walk you through the prerequisites.
1. IOS XE
  • Use show version to find which version running on your device
  • IOS XE 17.3.x to 17.9.4 are supported versions
  • Image must have payload encryption (i.e. image type must not contain NPE in its name)
  • To download IOS XE software, go to Cisco Software website
  • Here's a guide on how to upgrade IOS XE if you need
  • IOS XE Release notes here
2. NTP
  • Device has ntp configured (ntp server address).
  • Here's a list of public NTP servers in case needed.
  • And here's a useful guide
3. IP Routing
  • Device has IP routing enabled (ip routing)
  • Only default VRF is supported and a default route must be configured (ip default-gateway not supported)
  • Connectivity must be via a front panel port (i.e. management port not supported)
4. DNS
  • The device must have a DNS server configured (ip name-server address)
  • You can use Cisco Umbrella for free
  • The device must allow domain lookup (ip domain lookup)
5. Authentication
  • The device must have AAA enabled (aaa new-model)
  • AAA authorization must be set to start an exec shell with aaa authorization exec default local or aaa group name
  • If the aaa authorization exec default specifies a aaa server-group name first in the list, a aaa group server tacacs+ {server-group name} server group with that group name must be configured
  • Radius authentication is not currently supported
6. Loopback interface
  • The device must have loopback interface numbers 1000 or 2000 available (show ip int brief).
  • This will be auto-configured when the device is onboarded
7. VTY lines
  • The device must have at least five unused consecutive VTY slot numbers between 16 and 98 (show line vty 16 97)
8. Access Lists
  • There can be no existing ACL names that include the text : "MERAKI_BLOCK", "MERAKI_VTY_IN", or "MERAKI_VTY_OUT" (show access-list in | Meraki)
9. HTTP Proxy
  • Please note that HTTP Proxy is not supported
10. Configuration Backup
  • Backup the current configuration (copy run flash:config-backup.txt)
Version history
Last update:
‎Jan 24 2024 3:54 AM
Updated by:
