Using SNMP Inventory in GLPI with MR36
Xpineau
i just strat to implement the SNMP collect from GLPI and i have some problems with AP MR36.
I can collect informations froms switchs MS120 but not with MR36.
If i have a look in the sysobject.ids documented on this page https://glpi-agent.readthedocs.io/en/latest/database.html#snmp-device-ids-database i can't find the MR36.
Is there anothe solution ?
Regards.
Indeed, the MIBs clearly stop at pre-standard WiFi6, with the MR55.
5 Replies 5
Ensure that the SNMP configuration on your AP MR36 is correct. I also suggest you open a support case.
Yes the configuration is correct and i do the same with switchs and it works fine.
It's clear the MR36 is not in the sysobject.ids database :
Have you checked with  the support?
Crocker
This is a question for the GLPI vendor, not the Meraki forums. There's a good chance they have an updated MIB that needs installed that will contain the sysobjectID for the MR36.
