Radar Event Pattern Detected
Lourdes
Hi everyone.
Can anybody explain this alert to me and how can we resolve this?
Hope you can help us.
RaphaelL
Hi , it seems to me that the AP has recorded Radar activity on your channels ( 108,144  )
Are you using those channels ? Are the APs registered to the correct Country in the dashboard ?
You can manually exclude those channels if these logs persists
RaphaelL
Lourdes
Hi Raphael,
The channel is in auto so I think we are using it. The country in the dashboard is correct.
I deleted those channels.
Hope it works.
Thank you for the help.
MerakiDave
Meraki Employee All-Star
@Lourdes is sounded like you were looking for a high level explanation and that is simply that you are leveraging DFS channels (UNII-2 channels from 52 through 144) and in that particular frequency range there is the possibility of interference with RADAR systems.  So DFS, Dynamic Frequency Selection is required.  If the AP detects a RADAR event, they are required to change channels and remain off the channel where the RADAR was detected for a period of time.
This is not necessarily a problem, and there may not be anything to resolve necessarily, left alone it will self-resolve. But it depends on what your channel plan currently looks like, how much you depend on DFS channels to accommodate a certain channels plan, how often RADAR events occur, etc.  In some cases you might decide to allow DFS events to play out naturally and perhaps are non-disruptive, alternatively you might decide there are frequent DFS events that become disruptive to performance or a reasonable channel plan and possibly decide to disable DFS channels in the RF profile.  More details are in the documentation here https://documentation.meraki.com/MR/Radio_Settings/Dynamic_Frequency_Selection_(DFS)
Hope that helps.
Lourdes
Oh. I see. Thanks for the info. 😄
