Problem with MG21
OscarBengtsson
Problem with MG21
Hello community!
I have a Meraki MG21 that doesn't want to connect with Cellular. I've tried inserting the SIM card into a phone; it doesn't ask for a PIN code but says 'Carrier lock.' Does anyone know what this means? A quick Google search led me to understand that it might be if the phone had a previous provider, to which it is locked. But this shouldn't matter for the MG21 device, right?
The last thing i did was to connect it to the switch and enable safe mode for further troubleshooting.
Best regards,
Oscar
2 REPLIES 2
Have you tested with another SIM card? It doesn't seem to be an MG problem.
Thanks for the suggestion!
It's a remote site and we didn't have access to another SIM card, but that will be the next step to try for continued troubleshooting. I was mostly interested in finding out if anyone had experienced a carrier lock before and if that could have been the issue with the SIM card
