Insight Webhook limitations
ibrugnolli
Webhook support for Meraki Insight seems to be a complete different configuration, when compare with the Webhooks support config in the Organization->Configure->API and Webhook. In the config page for Insight Webhooks there is no support for templates.
Are there any plans to add template support to the Insight Webhook config in the same way as currently exists in Organization->Configure->API and Webhook ?
Are there any plans to integrate Insight Webhook configuration with the Organization->Configure->API and Webhook ?
1 Reply 1
MikaelDL
Hi @ibrugnolli, you're absolutely right.
There is an ongoing work to create 1/ a consolidated new alert page at the organization-level (within 6 months), and then 2/ merge different types of alerts over time into that new org-wide Alerts configuration menu.
Hope this helps
Mikael
