Meraki wireless authentication Issue
Rahulkumar
Just browsing
Hi Team,
can anyone confirm on Meraki wireless authentication through Azure AD ,or can we use authentication thru on-prem Radius server (windows NPS) Only .
wants to check best practice for radius authentication , using multiple meraki MR53 access point
Best regards
Rahul kumar
Bruce
Assuming you’re looking at doing 802.1x authentication, then your options are RADIUS (e.g. NPS), or Local Auth, which can be configured with an LDAP server for authentication services. If you’re looking to use Azure AD then you’ll need something that can ‘convert’ Azure AD to one of these, for instance a cloud RADIUS offering (e.g. JumpCloud), or the on-premises NPS offering.
Thanks Bruce
Could you pls. help with Best Practice Guide for authentication and also will be helpful if you can share  implementation and Troubleshooting Guide related to Radius /authentication thru 802.1x  as well
Best Regards
Rahul Kumar
How about this one @Rahulkumar?
Thank you so much
