LAN out to public wifi gateway
BChimp0
Hi there,
Thanks for reading.
I'm wondering if it's possible to place one of the physical switchports on our MX64 into the public wifi space.  In my perfect world, the client would be handled by Meraki NAT DHCP with its traffic going out through the wifi public gateway IP.
Thanks again!
Bob
Network-dad
If you are using the Meraki NAT on the Wireless you can not... You would have to use one of the other addressing and Traffic methods that allowed vlan tagging and tag it to a guest vlan and have that vlan on your firewall assigned to your "Public" port.
Dakota Snow | Network-dad Linkdedin
CMNO | A+ | ECMS2
Check out The Bearded I.T. Dad onThe Bearded I.T. DadThe Bearded I.T. Dad
1 REPLY 1
Network-dad
CMNO | A+ | ECMS2
