wireless printing
freddy7
wireless printing
our laptops use radius server for staff wifi. since this is not based on a SSID/password, how can I add a wireless printer so user can print
2 REPLIES 2
You can create a New ssid with psk for the same vlan.
Do your printers move? If not, Why not connect them to a switch?
Best option - only buy printers that support 802.1x, and then have them authenticate like any other user.  You may find your printer already supports this.
You may find your RADIUS server supports MAC bypass.  In which case, enter the MAC address of your printer into your RADIUS server.
