setting up Cisco Meraki equipment
menyarito
Hello community,
When setting up Cisco Meraki equipment for the first time, what information do we need before we proceed?
Thank you in advance
Accepted Solutions
UCcert
Re: setting up Cisco Meraki equipment
Hi @menyarito , correct. That should be enough to get you started.
Darren O'Connor | uccert.co.uk
8 REPLIES 8
UCcert
Hi @menyarito , what eqpt are you deploying?
Firstly, do you have an upstream firewall?  If so you’ll need to open up certain firewall ports to allow the Meraki eqpt to register out to the cloud.  You can find that information in your dashboard in the Help section.
Some quick start guides below which lead into the install guides
https://documentation.meraki.com/MR/MR_Quick_Start
https://documentation.meraki.com/MS/MS_Quick_Start
https://documentation.meraki.com/MX/MX_Quick_Start
menyarito
Hello @UCcert
we deploying Meraki MX68W.
When setting up Cisco Meraki equipment for the first time, we can say that we need an administrator account to access the Meraki dashboard?
Thanks in advance
UCcert
Hi @menyarito
so you’re setting up an MX device?
Have you received your eqpt and license from Meraki? Have you created a new Organisation and Network for your company and site in the dashboard?
https://documentation.meraki.com/General_Administration/Organizations_and_Networks/Creating_a_Dashbo...
Check out the "Getting Started" guide.
https://documentation.meraki.com/Getting_Started
menyarito
Hello All and thank you for your answers,
Not yet.
Yes.
Can we conclude that to configure Cisco Meraki equipment for the first time, we need:
1. Cloud Enterprise License.
2.Meraki Dashboard Account.
3. Meraki order number or the serial number of the device.
UCcert
menyarito
thank you so much.
God bless you
UCcert
Best of luck with your project
