Search instead for
iPhone texts not sending
I'm getting a few reports from iPhone users that texts are not being delivered to Android and non-iPhone numbers.  It seems iPhone-to-iPhone works fine, though.  When users turn off WiFi on their phones, texts are sent via cellular to. But once WiFi is turned back on, texts are not being delivered to Android phones.  I've adjusted the bitrate and dual band is selected.  Any suggestions on where else to look?
6 REPLIES 6
Re: iPhone texts not sending
@SteveNu I suspect that its an iMessage issue opposed to a Meraki issue. Have you tried contacting your cellular provider?
A TXT being an Apple and an Android device is - a standard TXT.  You need to contact your cellular service provider a log a fault.
Also WIFI Calling can be enabled depending on carrier feature to send/receive TXTs. Not sure what carrier is being used but just an FYI.
iMessages are being delivered to the recipient over WiFi.  Text messages are not being delivered to the recipient over WiFi.  Both messages are being delivered over cellular, when WiFi is turned off.  When cellular option is turned off, iMessage works, SMS text does not.  I don't see how it could be a cellular issue. Maybe I wasn't clear in my original post.
We believe it might be a port being blocked in our firewall.  Working with our network security office now.  Thank you everyone.
SMS is only sent over a cellular connection.  It is not sent over WiFi.
@PhilipDAthwhich is why i suggested wifi calling. TXT still works. Rather or not the carrier offers it is a different story.
