iOS and WPA2 with Radius Authentication
Son
Hi All,
We are about to deploy our Meraki wireless solution in our business and out of the blue a new requirement has come up which we were not told about before!
We have a requirement to allow some corporate owned iOS devices (iPads and iPhones) to be accessible on the corporate network, however, we are using Microsoft NPS server with PEAP authentication and a certificate from a trusted CA and allowing Domain Computers to be authorised onto the SSID. Obviously iPads and iPhones cannot be a Domain Computer so how is it best to utilise the NPS server and create a new policy to seamlessly allow these devices onto the network but restricting them by device not user. I guess some sort of MAC authentication would be best here.
We want to use these tools only at the moment not purchase anything else such as Cisco ISE as an NAC.
If someone could help and provide any documentation that would be great!
Sonny
Accepted Solutions
JohnT
Re: iOS and WPA2 with Radius Authentication
You have to add the user to the authentication group instead of the computer which will give the user access to the corporate WiFi.  If you also want to lock it down to a single device you need to enter the Mac Address in the "Verify Caller-Id:" field on the Dial-In tab in Active Directory.  If the user has more than one IOS device you will need to use regular expressions like A1B2C3D4E5F6 | A2B3C4D5E6F7.
10 REPLIES 10
JohnT
jdsilva
You should be able to install a cert from your CA via your MDM for corp owned IOS devices so they can authenticate to the WiFi the same way a domain machine would.
If you have permission, export the certificate from the computer (including the private key) and then import it onto your iOS device.
JohnT
The problem is that when you use NPS it authenticates the computer account in a security group.  I don't know of a way to add an IOS device to the domain even with a certificate.  Unless I'm missing something here.
Son
Hi John,
Thanks for this, so are we supposed to add the hyphens in as your screenshot denotes or should we just enter the characters only? See below a copy of our NPS policy, I had to create a new one to match the same SSID but this time with an AD user group which has the permitted user in who requires access with an iOS device and I have added the MAC address in the Verify Caller-ID for that user who i've asked to test. So all being well this will implement user / MAC authentication into one? Let me know if you spot anything incorrect with this?  Thanks!
JohnT
HI Sonny, that looks correct.  I usually test with the user first and no MAC address to limit the breaking points.  Once the user auth works, I add the MAC address.  I believe you need the hyphens.
-John
SantiagoGarces
on the SSID enable group policies and select whitelist to allow iPhones, Mac, IPad or whichever you want
Son
Massive thanks John this is working as expected.
Now got to figure out why the traffic is not being routed as expected for these devices! Hopefully it is not anything to do with the Radius policy but doubt it, will review that and raise another case if necessary!
Thank you
SLR
we are doing something similar and access via wifi on phone/handheld devices crossed my mind as well because I have all domain computers/users to be able to connect to the wifi
we are doing radius athentication - does the accepted solution apply to our use case scenario as well?
we will have guest wifi ssid I am assuming that would be WPA2-PSK with a supplied password. I guess all phones/handhelds can connect that way instead.
JohnT
@SLR If you are connecting with WPA-PSK this does not apply.  This is only relevant if you want to add your phone/handheld devices to the corporate wifi that uses Radius with domain authentication.  Hope this helps.
