how can i create a guest wireless user without an email?
Hi, the only way to create a guest user is with an email? my client only want a random password.
Accepted Solutions
Re: how can i create a guest wireless user without an email?
The only two ways to give access to the dashboard are user accounts with an email address or SAML integration.
You could technically create a fake email and set up an account so they are signing in with the email you created as their username and a password. They would then be able to reset the password from what you set it as after they log into the dashboard.
6 REPLIES 6
and with SAML integration i would need an email for authetication?
Likely yes. It would be integrating with another system which would almost certainly have emails tied to them.
thanks where i can find the documentation? do you have any link?
What you could do is configure the WiFi for pre-paid billing.  You can then pre-print the cards with have PIN numbers on them.  You can say that the PIN code expires after a set period of time.
https://documentation.meraki.com/MR/Splash_Page/Configuring_a_Prepaid_Card_Billing_SSID
