Zoom Sharing desktop
Ilene
I am wondering if other Meraki users have run into a situation that users are reporting having trouble sharing desktop while using Meaki wireless devices. I have the Guest network with NAT and the private is open to the LAN.
 I can understand why it wouldn't work on the Guest network but not sure why it won't work on the private
4 REPLIES 4
@Ilene How are you sharing desktop?  Teams, Webex, TeamViewer, RDP all work for me amongst others.
Ilene
My users are using zoom desktop. They say as soon as they disconnect from the wi fi ap then it works.
Bruce
Seen this (Zoom desktop sharing) working perfectly fine with users connected to MR 33/42 devices. Is there a firewall or something else upstream on the wireless SSID that could be causing the issue?
