Wireless speeds are less than expected.
RobMcLean
My network has 4 MR33 broadcasting a few different SSIDs each tagged on their own VLAN.
I am trying to transfer a fairly good sized file (12 GB) from 1 computer to another and it says it will take 27 hours.
When I look at the network speeds it is saying the transfer rate is about 135KB/s.
Where can I look to try and see if this is a network issue or a something else?
Computer 1 is connected to SW1 (MS-125-24p) at 1Gbps and the port is assigned to VLAN 6
The SW1 is connected to a MX-84 to provide L3
The SW1 is also connected to SW2 (MS-220-8P) via 2 1Gbps links configured as an LACP aggregate.
Computer 2 is connected to SSID 'internal' that is assigned to VLAN 8
Computer 2 is also a client of AP3 (MR-33)
AP3 is connected to SW2 via a a 1 Gbps trunk link.
31 Replies 31
RobMcLean
So this appears to be only affecting internal transfers.
I can redownload the same file from the internet at much faster (10 or more MB/s.)
I know it is not a computer 1 issue because I was able to push the file to computer 3 in about a minute or 2.
Computer 3 is connected to SW3 (MS-120-8) via a 1Gbps access port configured for VLAN 6
SW3 is connected to SW1 same as SW2, a 2-1Gbps LACP trunk link.
Computer 1 and Computer 3 are in the same VLAN.
Now I am wondering if this is an MX issue?
If you plug computer 2 into switch 2 what do you get, i.e. no wireless?
RobMcLean
So I plugged computer 2 into SW2 and configured the port as an access port in the same VLAN as the internal wireless SSID.  The speeds ran normal speeds, around 100MB/sec.
I then switched in back to wireless and the speeds dropped back to 100 KB/sec.
If you have an Intel chipset in the laptop,  particularly an 8260 or 8265, plug in the power adapter or disable all power saving on the NIC.  There is also another setting detailed on the wireless forum
RobMcLean
The 2 computers are Mac Minis.
Do they have wireless, or is it an adapter?
RobMcLean
Computer 1 is using built-in ethernet and Computer 2 is using built-in Wifi.
🤣 we've had a few Mac minis since 2015 and I never realised they had wireless!  It looks like the hardware is based on the Intel NUC at the time and that would be the 8260 chipset.  I can't be sure but if it is then I'd try an external adapter with a different chipset.  I'm almost certain that'll make things better.
RobMcLean
The wifi is:
 Card Type: AirPort Extreme  (0x14E4, 0x13B)
  Firmware Version: Broadcom BCM43xx 1.0 (7.77.111.1 AirPortDriverBrcmNIC-1669)
  MAC Address: 14:bd:61:f1:9e:f0
  Locale: FCC
  Country Code: DE
  Supported PHY Modes: 802.11 a/b/g/n/ac
  Supported Channels: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 36, 40, 44, 48, 52, 56, 60, 64, 100, 104, 108, 112, 116, 120, 124, 128, 132, 136, 140, 149, 153, 157, 161
  Wake On Wireless: Supported
  AirDrop: Supported
  AirDrop Channel: 44
  Auto Unlock: Supported
  Status: Connected
I do not think it is a computer issue.  If it was then all wifi traffic would be extremely slow, not just internal LAN transfers.
MM1 (Mac Mini) to MM2 wireless transfers 100KB/sec
MM1 to MM2 wired (over ethernet) transfers 100MB/sec
MM1 to internet 10-15MB/sec and sometimes more.
I did another test using my MacBook Pro and I see the same behavior, very slow LAN transfers over wifi.
GIdenJoe
Because air to air transfers need to pass the air twice there could potentially be an airtime issue.
If you would move one device to another AP that is on another channel I suspect the speed would be better again.
If possible I would look if you can run iPerf on MAC and do a long continuous transfer between the two MAC's and then monitor the live airtime on the MR33 both clients are on to see if you're not hitting 80%.
Another possibility is that you have a bunch of retransmissions due to a hidden node issue (both clients can't hear each other enough to determine free airtime).  Sofar I haven't seen any monitoring on Meraki that indicates retransmission rates so in that case you'd need to do an OTA (over the air capture) to determine just that.
Wireless STA to STA transmissions are always slower due to the crossing of the air twice but those speeds are ridiculously low of course 😜
Air to Air, as in both computers are on wireless?  I am not doing this.  1 computer is wireless and the rest are wired.
Clients that are wired up are getting great connection and transfer speeds.  It is the wireless ones that are suffering.
No matter which VLAN/SSID they are on, wireless to wired client traffic is slow.
GIdenJoe
Oh I see, I didn't pay enough attention.
So it's the wireless client that also has great download speeds on the internet but not from a file that exists on computer two.
In that case I'd still recommend doing the iPerf tests in different scenario's.  The iPerf test will eliminate the harddrive as a possible cause since it works on RAM alone.
Then you can easily move computer 2 on the wire but on the same VLAN you were dropping wireless traffic on, then moving the client on the same VLAN as computer 2 both wired and wireless and get to a solution that way.
The only things you can look at in the dashboard is the wireless RF stats on the AP, MX cpu, etc etc.
MichelRueger
WE did a lot of Iperf, but didn't find-out what the problem is. From a Macbook Pro to the Mac Mini (WLAN to LAN)
First Images is Iperf from Laptop (LAN) to MAc mini (LAN)
second Images is Iperf from Laptop (WLAN) to MAc mini (LAN)
What we see is that the speed is very unstable.
I don't have iperf on my network, but a simple 64 byte ping shows anywhere from 3 to 148ms for wireless connections.
MM1 to MM2 (wired client to wireless)
round-trip min/avg/max/stddev = 3.222/68.739/148.904/38.457 ms
MM1 to NAS1 (wired to wired, but wireless VLAN)
round-trip min/avg/max/stddev = 0.419/0.583/0.725/0.083 ms
MM1 to MM3 (wired to wired same vlan, but different switches)
round-trip min/avg/max/stddev = 0.461/0.779/0.879/0.124 ms
MM1 to MBP (wired to wired, same VLAN, same switch)
One thing I have noticed is that every wireless client, no matter the SSID shows the following.Screen Shot 2020-11-17 at 12.12.12 PM.png
A red X between the switch and the AP
GIdenJoe
You can hover over the red X to see why it is showing that.
I'm not sure what traffic/packets it is looking for here but this is for my work laptop and I have been working on it all day.
GIdenJoe
Is your AP stable?  (not jumping to mesh ?)
If you are not using mesh in your network you could disable the mesh feature on the network (network-wide -> general -> wireless meshing, disabled.
How would I know if it was stable?
If I disable mesh, will it knock out the 1 AP I have that is not attached to the wired network?
GIdenJoe
Yes that is meshing.
So if you are actually using that feature then please do NOT disable meshing.
You should look at the status page of the AP your client is on and check if it has full connectivity and there is no mesh route screen visible.  That would indicate the AP is in meshing mode due to a cable problem and traffic is not sent to the wire but to another access point thay may have a weak signal to this AP.
The Summary page lists Uplink traffic, not mesh routes.
GIdenJoe
Does the uplink traffic increase if you have your clients downloading a bunch of stuff on that exact AP?
It's just weird.  Unless there are simply no clients connected to that access point for a long while.
Yes, uplink traffic increases when I have a copy going. (Wired to wireless)
I wish there was a way to see the same realtime graph on wired clients.
If your laptop has an Intel chip, especially the 8260 or 8265, connect the power adapter or disable all NIC power supplies. The wireless forum also has a more detailed setting.
@RobMcLean if you look at the ports view of the switch, you can see the real-time data flow of the port
GIdenJoe
@RobMcLean :
My answer was referring to you about the iPerf.
Do you also ping from MM1 wireless to the internet?  Also bad or OK?  If bad then it is a pure wireless issue.  First test with another client to rule out any firmware bug.  If issue persists then you'll have to check your wireless environment (check the live RF stats of the AP on the band you are connected to 5 GHz preferably)
@MichelRueger As stated above the iPerf response was meant for Rob 🙂
Your iPerf however does show a nice base speed with a drop at the last few transfers.
You'll also  have to check if there was other activity on that particular channel.  If you're alone on your Wi-fi channel then you will have awesome speeds, however if alot of users are on that channel your device will have to wait longer and perhaps even experience more collisions (hidden node maybe?)  so at those times you can have severe drops in speed.
Ping from MM2 (wireless)
--- google.com ping statistics ---
10 packets transmitted, 10 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 20.560/26.561/37.661/5.670 ms
Ping from MM1 (wired)
round-trip min/avg/max/stddev = 16.409/22.879/29.263/4.351 ms
Not a significant difference
MichelRueger
I have the Same Problem at the Moment with MR46 AP. I do not get more that 130Mbps true WLAN. If I connect the Macbooc or a Lenovo Laptop to the same Switch with Kabel I have full gigabit Speed.
I did already a lot of Testing an it is a little bit better with a Ubiquit AP but still not what it should be. I also do Speed-test with IPERF between a Mac Mini and the Laptops.
If I do the Speed-test from a Laptop connected to the Ethernet Kabel to the Mac Mini I gor full speed, so I dont think it is a Problem of the LAN Port from the Mac Mini.
CTU
Apologies for bringing this message up from the dead - I wondered if you ever had this resolved, as I'm getting a similar issue with Wifi <-> LAN traffic.
RobMcLean
I never figured out why I was getting such horrible speeds fro Wifi <-> LAN, so I finally just gave up.
One of my posts mentions a red x in the connection graphic between the switch and the AP.  I opened a case with Meraki in Dec and in late March of this year, they deployed a fix for it. "The development team has deployed a fix for this problem. You should now be able to see relevant data for your wireless clients on the clients page."
I now get decent speeds transferring files over Wifi to LAN, but I don't know what actually fixed it.
I'm also running the latest stable RC firmware on all my devices.
CTU
Hi Rob
Good to know that you go this sorted out, even if you don't know why/what the problem might have been.
I don't see the red cross between the devices as you did.
Craig.
