Wireless Splash
Just browsing
Wireless Splash
Im new to Meraki, recently passed CMNO training.  My question, is there instructions on how to do some custom designs?  Items like add a photo/logo, add vertical fonts, different font styles, etc.  I work at a school and Im trying to spice up the splash screen with the new school year for students and staff.  I see you can add colors.  Should I add this to the wish list.
Accepted Solutions
Re: Wireless Splash
Hi
Hope you have referred the following url
 https://documentation.meraki.com/MX-Z/Access_Control_and_Splash_Page/Customizing_the_Splash_page
However as Adam said one should have HTML knowledge to customize.
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
5 REPLIES 5
Re: Wireless Splash
Your ability to customize is pretty limited.  You can certainly add a logo.  Wireless>Splash Page and see the Splash Logo section.  You can also do some basic html in the message section.  I'm not sure how robust this is but you may be able to work/hack something in there.  Lastly, you also have the option to redirect to a certain web page after they've auth'd and you could do more stuff on that page since you'd fully control it.  But beyond that I'd assume any customizations would need to be a wish 😉
Just browsing
Re: Wireless Splash
Thank you for your reply. I will add to wish list. Just thinking as to my doctors office splash page and was asking if Meraki could do the same.
Re: Wireless Splash
Hi
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
Re: Wireless Splash
@Tpeters I will second the posts from @Adam and @AjitKumar and also wanted to make sure you were aware there's a whole external captive portal API at your disposal.  Check out https://create.meraki.io/ and check it out, there's a write-up complete with flows and example code that can get you started on more sophisticated splash pages than what you can accomplish natively in Dashboard.  There are also several developer partners who offer professional services to build and support such requirements.  Hope that helps.  Oh and congrats on your CMNO!
Just browsing
Re: Wireless Splash
thanks!
