Wireless Issue
FXE
Just browsing
Wireless Issue
I am new in Meraki technology.
I changed my gateway to a Firepower and we noticed that we are encountering intermittent issue in the wireless environment.
I checked the Meraki dashboard and I saw multiple PSK authentication fails something like this,
"type='WPA-PSK auth fail' associated='true' radio='1' vap='1'"
May question now, what is process for user to connect to the wireless network? Does the user only needs to communicate to the AP or does it needs to communicate also Meraki Cloud?
Thank you so much for the enlightenment.
6 REPLIES 6
Re: Wireless Issue
If you are using PSK, which the error indicates, then no cloud communication is required to authenticate the user.
Re: Wireless Issue
@FXE The AP is the only thing that needs to communicate with Meraki cloud.
Re: Wireless Issue
That looks like a fat-finger to me. Have you looked at Wireless Health vs the event log? It'll identify culprit clients for you easily, as well as help diagnose where in the process wireless is hitting problems on a per-AP basis.
FXE
Just browsing
Re: Wireless Issue
Hi @Nash, yes I checked the the Wireless Health and the Event Log and I saw those logs about PSK errors.
I am stuck already where to check next since we guaranteed that the PSK that we are providing is correct.
Re: Wireless Issue
If you're providing the correct PSK and other people can't enter it correctly... that's kinda a them/their device problem honestly?
Have you had them forget the network, and then try re-entering the PSK?
Re: Wireless Issue
I see a ton of these errors in Wireless Health for our company phones which have the PSK pushed down by an MDM so I'm in the same boat - I know the PSK in not incorrect.
