WiFi 6 - Do I need to have both bands 2.4GHz and 5GHz enabled for it to work properly
Captain
Do I need to have both bands 2.4GHz and 5GHz enabled for WiFi 6 to work properly.
Please note that my question is regarding WiFi 6 and not WiFi 6E.
If i have an area which I have disabled 2.4GHz due congestion and left only with 5GHz enabled then
 * Would I be able to use WiFi 6 at all?
 * Any cons (affecting wifi6...) due of 2.4GHz is disabled?
 * How can I check if a client is connected using WiFi6?
Thanks in advance for all helpers!
3 REPLIES 3
Wifi6 works on 2.4 as wel as on 5ghz.
Disable 2.4 is not a bad thing at all.
Dashboard does not show if clients are connected using wifi 5 or 6. It shows the client Capable Wi-Fi standards, so you could asume its using that
Samsung phones show a 6 next the the WiFi symbol when connected.
GIdenJoe
Unlike Wi-Fi 5 (802.11ac) Wi-Fi 6 also supports the old 2.4 GHz band.  You can work in either band as you see fit.
The usual use case I see for the 2.4 GHz band is for IoT devices.  And then use 5 GHz (and 6 GHz in Wi-Fi 6E) for all your bandwidth hungry devices.
Make sure to check your RF profiles in dashboard to see if the disable 802.11ax box is not checked.
