Walled garden only IP Adress Possible
MichelRueger
Why is it the default that in the Wireless Access Control Settings, we can only enter IP Adress in the Walled garden?
I know that if you open a case you can ask that URL entry possibility is activate. I don't understand why IP id the default and not URL.
Regards Michel
2 Replies 2
Chris_M
Possibly because an URL requires DNS and if you forget to whitelist DNS, then you cannot get past the walled garden. To "idiot-proof" this, you require an IP address instead.
Find my post helpful? Please give me a kudo!
CCNP Certified and Meraki Operator
MichelRueger
Thanks for the feedback, I understand the Answer, still think it is more Easy to add all the necessary URL's that the IP.
Thanks Michel
