WPA-2 Enterprise with Radius and Duo
G_ControlScan
To All,
Has anyone been successful in setting up an SSID, with WPA2-Enterprise with "my RADIUS server" authentication with 2FA to Duo? I manage the Meraki network although a 3rd party manages the servers and the 3rd party states Duo does not support 2FA over Wi-Fi, but Duo 2FA does work over Meraki Client VPN. Thanks for your input.
1 Reply 1
I think it would technically work if you use the "push" notificaiton option.  This shouldn't need anything extra from the RADIUS client (aka the AP) and the RADIUS server only needs to send an ACCEPT/REJECT.
However I can see several caveats.
  • Roaming could be a real pig.  Especially if you are between two APs in a fringe area.   You may get a lot of push notifications if re-authentication happens.
  • Every time you walk into coverage (such as when you come to work every morning) you'll get a push notification.
I think it will be a real pain.
