Voice Vlan tag on Meraki MR33
celma972
Hi
I have 30xMR33 in my warehouse all of them are setup with a SSID using radius. This SSID is used for Data only and is on the native VLAN (vlan 1).
I  have added and setup a new SSID for Voice only
I would like the additional SSID use the VLAN 2 for Voice. Is it the correct configuration to have on all the 30xAP for both SSID working for wireless datas and voice equipements working?
Our switch are Cisco 2960. I can ping the voice and the data subnet from the AP.
this is the show Vlan on the core switch
IWRcore#sh vlan
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/2, Gi1/0/3, Gi1/0/4
                                                Gi1/0/5, Gi1/0/6, Gi1/0/7
                                                Gi1/0/8, Gi1/0/9, Gi1/0/10
                                                Gi1/0/11, Gi1/0/12, Gi1/0/15
                                                Gi1/0/16, Gi1/0/17, Gi1/0/18
                                                Gi1/0/19, Gi1/0/20, Gi1/1/2
                                                Gi1/1/3, Gi1/1/4
2    SUB_109_                         active    Gi1/0/21, Gi1/0/22
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
2    enet  100002     1500  -      -      -        -    -        0      0
3    enet  100003     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
Thks in advance
If this ssid need to have vlan 2 on all your APs you can remove the voice line/tag and just set the All other AP vlan to "2"
If you want different APs to set different vlans for this SSID then you can use TAGs to apply that to a AP.
https://documentation.meraki.com/MR/Client_Addressing_and_Bridging/VLAN_Tagging_on_MR_Access_Points
3 REPLIES 3
SwitchPort to the AP is a trunk port with vlan 1 and 2?
celma972
Hi Kudos,
Are you taklking about the switchport command on the switch?. If yes, I know that one.
But I am trying to understand this "all other APs"
