Is it possible for email notifications to be sent to approvers when a new guest wifi account is created by the guest user? This relates to a Sign-on with Meraki authentication set on the SSID.
The example I can provide is:
Guest enters their details via sign up page.
New account is created and visible on the User management portal. Details sent to guest user.
New account isn't approved until an approver verifies.
It's at this point that it would be useful for an email alert advising that a new guest account needs verification in the User management portal to be sent.
Phil
Solved! Go to Solution.
Thank you for your responses.
Found what I was after in the end with a little help from support:
Network-wide -> Alerts -> Wireless -> A new user registers via splash page.
From here you can simply add email addresses you would like to be notified when a new guest login is created via the splash screen.
It sounds like you want sponsored guest mode. Note this is not visible in the dashboard by default. You have to open a case with support to get it turned on.
https://documentation.meraki.com/MR/Encryption_and_Authentication/Sponsored_Guest
At least this feature is publically documented. 🙂
Also, before anyone goes reaching out to Meraki support because they're missing that feature in the alerts page. It's only displayed when you actually have SSID's with self-registration splash pages. 😉
