Upgrade estimated time
Hi everyone. I want to know how much time it takes to upgrade an Access Point MR66, MR18 & M16?
Thank you 🙂
Accepted Solutions
Re: Upgrade estimated time
Hi @Noah014 , very little time. The AP will upgrade whilst still actively serving clients then it will reload.  During that period it will drop off then reconnect once registered out to the cloud again.  Approx 1-2 minutes
Darren O'Connor | uccert.co.uk
4 REPLIES 4
Thank you 🙂
I have another question, the AP will register automatically or it will be necessary to register it manually?
If it’s already registered prior to the upgrade it will seamlessly re-register. You literally need to do nothing except schedule in the upgrade or hit “enter upgrade now”
Bit of light reading on best practice for Meraki firmware upgrades
https://documentation.meraki.com/Architectures_and_Best_Practices/Cisco_Meraki_Best_Practice_Design/...
