Unable to find a gateway
Hello all,
its me again.
currently i have 2 AP's connected to Meraki switch.
1 works fine but the other doesnt.
Error: Unable to find a gateway to the internet.
AP is getting all the right ip information but i cant event ping or traceroute the gateway.
this is the first time i have plugged 2 ap at the same time.
Can you guys please help.
4 REPLIES 4
Re: Unable to find a gateway
That usually happens when the AP has an issue with its connection to the switch.  Perhaps try plugging the AP directly into the switch with a patch cord.  Make sure the switch port it is plugged into can get an IP address and can talk to the Internet (perhaps plug a notebook in to double check).
will try to do that.
Are you able to see the AP on your Meraki dashboard?
Are you able to access the local device status page (enter IP address in browser)?
On the physical AP - are there any lights that might give you a clue?
i can see it in dashboard. red icon.
havent checked if i can access the individual AP.
AP is attached in the ceiling. will be checking it out in sometime and let you know.
