U-APSD failures
JohanPlukon
U-APSD failures
Hi all,
I was wondering if anyone else experienced the same problems or maybe has found a solution.
A couple of months ago we have setup a location with new MR36 and MR76 accesspoints.
In this network an exteral supplier has implemented a VOIP solution from the brand Mitel with 5634 of 5624 Wifi handsets.
Since the implementation we have problems with the WiFi handsets. From an airtrace we found out that the AP's keep sending data to the Wifi handsets although they are in powersafe mode.
Mitel is stating it is caused due to the fact that the issue is in U-APSD is not working propperly on Meraki side.
2 REPLIES 2
Are you running a current stable (or better) firmware release on your Meraki APs?
JohanPlukon
Im running on the 28.6 firmware
